Rechargable 6v Batteries
laserman2000
Where can I get a rechargeble 6v lantern battery like this but rechargeble
WildRice
SW Michigan
open one up and replace the cells with 5x NiMH. This would most likely be cheaper then finding one already like it.
Jeff
rwolff
Ontario, CA
Another method that should work (lower capacity, but simpler charging circuit) is to use 3x sealed lead acid cells. Hawker Energy makes a "D" size (not drop-in interchangeable - connection is via twin tabs on top) 2.0 amp hour (and a somewhat larger 4.0 amp hour). You can definitely fit 3 "D" size into the space of a spring terminal battery (there are commercial adapters that hold 4 "D" cells and replace a spring terminal battery). Depending on how you pack things, you may be able to fit 3 of the larger cells, or 6 "D" size (2 parallel connected strings, each with 3 series-connected cells) into the space.
andrewwynn
Racine, WI USA
Neat idea with SLA.. they are awesome if you don't have a problem with weight.. they are so hard to hurt and so easy to charge.
-awr
snakebite
dayton oh
i gutted a dead eveready with a plastic case and installed 4 f cell nicads.its a tight fit .
Lynx_Arc
Tulsa,OK
I bet you could just about use 8 subC nimh cells in a series/parallel arrangement. My rough guess is you can put 18 of them in the space of a 6v lantern battery so 15 in 3 sets of series/parallel would give you 6-7.2v roughly. Also you don't have to have 6.0v as most 6v devices are designed to run off of 4.8v, so you could easily get by with 4 cells as snakebite did.
WildRice
SW Michigan
The last time I open a 6v battery like that was ....sheegh..20 years ago... anyway it had 4 cardboard lined 'F' calls, and it was potted with 'tar' looking stuff. LM2K, it is safe to open the battery casing, as long as you dont use certain tools, like... drills, hacksaw, axe... ya know, stuff like that. The rectangle box is just that, a box for the 4 steroid injected 'D' cells.
Jeff
andrewwynn
Racine, WI USA
I like the sub-C idea.. you can get 3500mAH NiMH.. they are very cool 'squarish'... my drill batt. has 13 of them.. 60WH of storage!
-awr
bfg9000
Forget 8AA to 2D adapters, I wonder how many AAs will fit in a 6V sized box! Any $4 lantern also has a giant reflector and could be good for modding. As for SLA, you could simply buy a cheap "1m candlepower" rechargeable spotlight with a 6v SLA for $10, that probably already has a bigger reflector than a lantern, as well as an H1 or H3 bulb.
