[Review] - Fenix E12 v2.0 - Mini EDC Flashlight - AA 160 lumen - by Lock
Burgess
USA
So am I to understand that
Energizer Ultimate Lithium L91 cells
are NOT acceptable for use in this ? ? ?
Very Disappointed if that's true . . . . .
:shakehead
_
moshow9
El Paso
:shakehead
_
Not the case. Li-ion batteries are not recommended/banned by Fenix in use with this light. A Non-rechargeable Lithium Battery (primary) is listed as usable on the battery specifications.
Sos24
:shakehead
_
I am not certain but I think theyEnergizer Ultimate Lithium would work fine, based on what Maxlcon said and that they run on the same voltage as Alkaline and Ni-MH. I think the lack of recommending lithium is because they are not designed to handle the higher voltage of a 14500 lithium rechargeable and afraid people would get confused.
aznsx
Phoenix, AZ USA
Yeah. As Mosho9 pointed out, in the User Manual (at least in the Operating Instructions I just checked on the Fenixlighting site), "non-rechargeable lithium battery" is specifically listed as "allowed", and "rechargeable lithium ion battery - 14500" is specifically listed as "banned". As reluctant as some are to read them, and even as poorly-written as some of them are, User Manuals / Product Instructions docs often provide information, or more clearly-stated information than one finds in the 'marketing fluff' docs. Product reviews should also always specifically call out all power supply options clearly.
Burgess
USA
Thank you, Everyone,
for your answers !
Good to Know !
:twothumbs lovecpf
_
pc_light
Old Dominion, USA
Just an FYI, I tried a 14500 in my E12 v2 and it didn't go poof but it also didn't get crazy bright.
The current draw on a 1.2V NiMH was 1.50A and on a 3.9V Li rechargeable was 0.48A. So, it would appear there is some constant current regulation circuitry involved. I don't have a light meter but actually all three levels were relatively similar in power draw and output light levels. Further testimony of what appears to be a well-regulated driver.
Since there isn't any appreciable bump in lumen out-the-front, I will probably stick with NiMH to be safe. I can't vouch for long-term viability but it's good to know I don't have to worry about accidentally sticking a 14500 in the light and frying the thing.
(Also, sticking with AA is a good ideal from a warranty perspective.)
sandalian
ICAO:WARJ
Thanks for your review.
The TIR is unique and I really want to try.
At the other side, the greenish tint color is a bit unamusing for me.
cave dave
VA
I don't have an E12 v2, but I do have the E20 v2.0 and I highly recommend it. The beam from the micro TIR is great for walking and the tint from the SST-20 is also very nice (guessing around 5500k). I wish they had used a 5000k SST-20 for the E12, I'd buy it in a heartbeat, but as it stands I'm passing because of LED choice. The E20 v2 is also surprisingly small. 5.0" long and thinner than I expected. Same length as some 2xAAA lights and 18650 lights. If you can stand the extra length of the E20 you get more power, way better runtimes, and a possibly a better tint than the E12, and it still hangs in your pocket without bottoming out.:thumbsup:
CPF review of E20 v2:
https://www.candlepowerforums.com/v...-Fenix-E20-v2-0-(SST20-5500K-250-lumens-2xAA)
Olumin
"...that famous Texas part of Hamburg"
I bought this light a few months ago. I was very pleased with it. The beam was very even, and I didn't detect any green hue. Looked white to me. Mode switching worked very well. Brightness levels are well spaced. I ended up gifting it to my sister. It's a good light to give away, due to it taking AAs and having a simple interface.
Only thing I can complain about is the clip, which really doesn't work very well. Same simple two-way clip that most manufacturers use today. Pocket material always snags on that "ramp" just below the clip-on ring. Couldn't conveniently pocket it one handed. Most of these "clip-on" clips have the same issue.
