Yes the replacement deck arrived a few days ago, and the laser built it that night.
Your original laser was the third unit ever built, since then i have standardized the procedure to build these. The upgrades are as follows:
1) High Q 0.1uF ceramic capacitor.
2) high precision Metal film bias resistors.
3) The use of high grade indium tin gold alloy solder for the laser diode connections, (the first 5 had indium tin bismeuth solder, and this is what probably failed when it was banged)
4) The mating surface of the elctronics support, switch mechanism, and + junction are solder filled and flush ground for reliable electrical connectivity
5) Slow setting epoxy is used to pot the upper electronics assembly to minimize air bubbles and allow for optimal adjustment of collimation.
6) Diodes are burned in for 36 hours to ensure they are OK Then the assembled modules are run for 24 hours to ensure reliable operation, then run for 3 hours more while the epoxy sets
Just pack the dead one in a bubble mailer and send it off, since that's usually the way they're shipped.
Also, the retail price has been dropped quite a bit, the BIN price is now $350.00, NOT 808.00 and i will be listing several of them on ebay in BIN/BO format for either the complete module or a 5-6v hardwired adjustable focus module for perminent installation.
FWIW, I've gotten emails from people using these from everything from rapid prototyping machines, to gene scanners, to gem testers and scanning conofocal microscopes!
Also, I am now 100% sure the optical platform assemblies the diodes come from are seconds or rejects that failed initial testing, ~As if the horrid packing wasen't enough of a clue!~ only 4 out of 25 worked as intended when i installed it in a PS3 game console! Of the dead ones 2 wouldn't read blue-ray disks (1 had a totally fried VLD, the other had a terrible beam mode structure), and ther rest wouldn't read ANY disk not even music CD's! I have a hunch the problem is the miniture auto focus servo controller unit, or the lcd thingie.
