Fern
Red-T - at very close range the dark clover-shaped center is there on mine also. There are various colored rings in the spill/corona as range is increased noticeable on white wall especially but I believe this is just typical of a smooth reflector.
burpee - The reason I was moving the light around was to make it easier to see the donut hole and ring effect. It's just not anywhere near as distinct in the video as it to the naked eye. It is obvious regardless of what object the light is illuminating, that's why I noticed it immediately. I understand what you mean about holding the hot spot steady then moving back and away, I tested this several times with a friend to check if I was imagining it
As I mentioned it was quite difficult to capture the effect on camera. Still shots were impossible because the reflected light was too great even on medium level and the hot spot looked completely full, white and 'normal' regardless of camera settings/setup and target surface.
That's why I switched to video.
I am very concerned this beam pattern is abnormal and will affect throw negatively. I have still not received a response from Fenix regarding this matter.
