Okay, I dug out the manual and figured out how to lock the movie camera exposure setting and color correction settings.
Color tint shift with current adjustment
I specifically noticed during my forward voltage testing of the Seoul P4, that the color shifts dramatically with current levels. Two things can cause this, one being the die color output, and the other is the phosphor (some YAG phosphors will drop as much as 60% lower output as the die heats the phosphor).
An example of what happens to one type of YAG phosphor is shown here, with the red line:
http://ledsmagazine.com/press/14132
It is unknown to me as to what is actually causing this in the Seoul P4 LED.
Anyhow, like I mentioned, I locked the exposure and white balance in the camera for this movie I took to demonstrate the color shift. The current runs from 400mA to 1.1 A in the video.
The movie is located here:
http://www.molalla.net/~leeper/seoulp4t.wmv
I'd estimate the part is moving from a very strong X1 bin (greenish-yellow) to way out beyond the end of the YA bin. At 400mA it is greenish-yellow and at 1100 mA it is blue. Pay attention to the corona color around the hotspot, since the camera is oversaturated in the hotspot and doesn't represent color that well there.
Thoughts-
The P4 LED appears to tint shift a lot more than other LEDs with drive current level changes, and hopefully it is just due to heating effects on the phosphor.
Early thoughts-
I'd consider agressively pursing very good thermal transfer techniques in an attempt to help mitigate the tint shift in the Seoul P4.
My plans for checking this out further-
Getting a thick copper plate and directly soldering the Seoul P4 to it. Then to thermal paste this plate to a large CPU heatsink with a strong fan. Then retest to see if it actually will help or not.
The Seoul P4 has a rather low thermal resistance 6.9 C/W vs. 8 C/W for the CREE XR-E, and they use the same CREE EZ1000 die in them. The LumiLEDs K2 has a 9 C/W. I don't notice tint shifting in the K2 or the XR-E that is anything like what the Seoul P4 is demonstrating. (or even the Luxeon III with a 13 C/W for that matter)
With the Seoul P4's very low thermal resistance being in the same range of other newly introduced LEDs one would figure the shifts should be similar. The shift in the blue wavelength (affects interaction with the phosphor), and also the shift due to YAG phosphor heating, should be less, unless they are using a different phosphor blend than LumiLEDs or CREE is utilizing (which is quite possible).
I hope to explore this further by directly soldering the part down to get rid of the thermal resistance of thermal epoxy and agressively heatsinking the thermal energy out of the Seoul P4 die.
The movie doesn't work for some folks, so I snapped a snapshot from two points in the video:
