Re: SF \"Classic\": host to drop in LED light engin
Well, I put this booger together. Some notes:
1) Assembly was harder than I thought it would be. I had forgotten how much of a help the ecan is. Messing with a seperate battery contact PCB is a big pain. This would have been easier if I had used stranded wire instead of solid wire, though.
2) Potting things like this without an ecan is a mess. /ubbthreads/images/graemlins/smile.gif
3) My 6P bezel doesn't screw all the way down with the McCapsule installed. It's about 1-2 mm off.
4) The M2 bezel doesn't have this problem because the shock isolation lets the reflector move up more into the head, giving the capsule more room before bottoming out. On the other hand, the shock isolation may remove a major thermal path. More testing will be needed to see if this is significant or not. Likewise, I don't know if this package will be able to provide enough thermal relief for a 5-watt for long runtimes. I'll have to build another with a 5-watter and see. /ubbthreads/images/graemlins/smile.gif
5) I thought centering was going to be a pain, but the great thing is the reflector sort of self-centers when you screw the bezel down. As long as you get the emitter "pretty close" to centered, you should be OK.
6) The reflector scrapes the outer edge of the top of the McCapsule, wearing the HA off a bit. Not really a problem, just an observation. I don't know if this is correctable or not.
7) When the bezel is unscrewed, the reflector backs out a little, which means you have to screw it back in before replacing the bezel. Not a big problem, but a minor annoyance.
Overall, I really like this mod, but I didn't like building it because I've been spoiled by the ecan. Once the McCapsule was complete, though, I didn't care about the build process. Now I have a reason to use that old 6P! /ubbthreads/images/graemlins/smile.gif
Some pictures:
[larger image]
[larger image]
[larger image]
[larger image]
[larger image]
