Starlight,
Got it. But you know you still need a charging cable, right? I can do the same for you as I did for Raindrop: I will send your USL CC with your M6-R order (assuming you haven't already gotten your USL).
However, that said, I've already promised Crossman451 and seattlite that they were next in line, so you will now appear right after them in the list.
Everyone,
More orders will go out after this weekend, or possibly on Saturday.
*A NOTE*
These packs are not Li-ion chemistry. They are NiMH. You can't let them sit around for months and months and months at a time. They need regular care and attention. Every two or three months (at the outside) give them a charge--AND if you think the pack will continue to just sit around for ANOTHER two or three months, then right after charging, discharge 50 percent of the capacity in preparation for this long rest time. THE WORST thing you can do is to take a fully charged pack and just let it sit for a year or two. You are almost guaranteed to reduce capacity or even kill a cell.
IF YOU WANT TO JUST LET YOUR M6 SIT AROUND INDEFINITELY BY YOUR BEDSIDE OR IN YOUR CAR, THEN USE 123's AND SELL YOUR M6-R PACK OR CANCEL YOUR ORDER.
And, similarly, even though the brightness of the M6-R will not necline until the bitter end (for the cells) IT IS BEST TO KEEP YOUR M6-R PACK TOPPED OFF. As I state in the directions that come with it, top off your pack every couple weeks at least (if you are using it in that time). Ni chemistry batteries like to work; they like to be active.
As I said, if this maintenance issue is a major problem for you, then you should consider selling your M6-R pack (or canceling) and using 123's instead. They can sit for many years at a time and be just fine for when you suddenly need them.
