It looks like a nice one. Can I use this on 230V with a power plug converter?
Where are you purchasing this charger? I see it at kaidomain. It was at a site e-lectronics.net, but they have taken it off as an offering.
Anyplace else?
In the meantime I've done some cycles using Shekor as well as Pila. When discharging at 400mA (~ 0.5C) using a professional electronic load, I was amazed to find both of them to have charged in about the same amount of mAh. The battery used was an UF XSL 18350, discharged to an end voltage of 3.0V. Shekor gave 804mAh and Pila gave 798mAh. The difference might be influenced a bit by differing resting times. This battery had shown a capacity of ~850mAh in a previous test, but then charged by an Orbit Pocketlader and discharged at only 180mA to a lower end voltage of 2.8V.
So the Shekor seems to be a reliable charger providing good results at a very decent price. I just have ordered another one to finally being able to give a charger for LiIon batteries to another person with a clean conscience.
Thanks for the hint at this charger! :thumbsup:
Wulf
Re this charger, it indeed does look interesting. Does it have polarity protection?
Bill
... The graph named "Shekor"...
Wulf
The side of the box claims that it does, i.e., 'Lithium battery position and negative polarity protection'. Someone needs to test the claim, though...
Thank you for your post and those graphs. I am new to this hobby, and that one post has explained to me concisely what CC/CV behaviour is lovecpf
I am considering getting this charger, after having a WF-139 delivered less than 2 weeks ago and reading so much on how unideal its charging behaviour is. I only have two pieces of 14500 li-ion cells now, is it overkill to buy another charger so soon?
Old4570, not being picky here, cause I know what you meant when I read it, but there are those who might misunderstand. In your first post and some subsequent posts you used CR123A as a Li-Ion being charged, and you meant RCR123, or RCR123A. CR123A is a primary Lithium, non rechargeable cell.
Bill
I got my SheKor last week, along with some 18650 batteries. I've been charging up some 14500s and using my simple analog battery tester, the 14500s stopped charging at around 4.1V - definitely below 4.2V. Maybe I'm unduly influenced by the other positive posts about this charger, but the peace of mind it is giving me is worth the money alone. I'm tempted to throw away my WF-139, which is near new and never gave me any problems.
THe WF-139 also shuts down on completion [ Later one ] , well mine does .
Its a great 18650 14500 17670 etc charger as long as it does not over charge .
I find the Shekor just perfect for the little 10440 batteries , it does not try to force 4.2v into such a small cell , esp as the 10440's I have seem to have increased resistance to going 4.2v [ possibly due to there size ] .
How would the WF-139 overcharge if it shuts down on completion?
Well you have two alternatives, sell the WF-139 or return it if you can! :twothumbs
Is anyone actually using the included power supply with a 220-240V input? I know these cheap switching PSUs included with chargers have had a tendency to die or blow up when used with 220-240V even though they're supposed to be compatible. Given the wide input voltage of the charger I can probably find a power supply to reuse so is more out of general interest then anything.
