Kevin1322
Both are the 3.7-8.4v. The new ones/versions. The only advantage I saw was that the XML did not heat up as much as the XPG and has a warm tint. Both using AW 18650 protected. I also tried using AW RCR123's, still the same, XPG defeated the XML. I got two XML's, 3-mode and the 5-mode and comparing it with my current XPG 5-Mode, XPG is brighter.
So, you used 2 x RCR123s and the XPG is still brighter than the XML? That's not right at all. The XML should be twice as bright. I could see that one 18650 battery may not push the XML to full brightness as it is designed to use up to 8.4v, but with two lithiums it certainly should. That's a real bummer as I just ordered a SF XML drop. It is the 3 mode 4.2v one, so maybe I'll get lucky.
