gunga
Is tha new T4 kit E-series compatible? Or is it P60 host size?
I'm interested...
I'm interested...
So has anyone ordered a T4 yet or do I have to be the test dummy? And yes I also would like to know if its e series compatible...
I have a small amount coming my waySo has anyone ordered a T4 yet or do I have to be the test dummy? And yes I also would like to know if its e series compatible...
I burned up 4 Dremel cut off wheels removing the spikes and used a few sheets of drywall sanding screen to shorten it a little further and smooth it out but it came out pretty good I think. Now the flat SS bezel ring is shorter than the black Al one that also came with the Klingon. It lives on my 2X18650 Leef tube running a M60WL. All the bezel strength, none of the impalement!
Yeah I WISH!!!!!!Next time try the diamond cutting wheels if you are using a dremel tool. If I were you, I'd use bench grinder with cutting wheel installed, or to use a mill.
A little mixing
No, the L2m does not turn on w/ the Z48 =(
