Repost of the "List"... Any changes/requests please PM or e-mail me as well as posting - I'm also keeping all this info on a spreadsheet for Eric, and want to keep it as accurate as possible. I may miss just a post.
THANKS,
Greg
1 WAVE PARTICLE P4-WH 240ma (0.75 watt), 25 mA Cancelled
2 FlashInThePan 50, 1.50, P4-WH (confirmed) Possibly High CRI emitter
3 coyote 25, 1.50, Q5 (WD tint prefered) in for 2. Also Two R4's when available per post #610 on original sign-up list.
4 russtang Q5 or highest bin with .75 high and 25ma low (confirmed) And a second one on the second list :thumbsup:.
5 baylisstic 25, 1.25, Q5/R2
6 BeamJunkie 50, 1.5, Q5/R2-WD or highest bin available (head only) (confirmed)
7 Manzerick 25, 1.25, Q3
8 cqbdude ?, ?, Q3
9 gjg 50, 1.50, R2 or best bin available
10 marcdilnutt 25, 1.50, P4-WB (confirmed)
11 cy P4-WH, 1.25, 50mA (paid) Cancelled?
12 Thujone Cancelled
13 quantile P4-WB, 1 W on high, 50 mA (paid)
14 Nell Q3 (will specify specs. later)
15 Sharpy 50, 1.25 Q3 and 75, 1.50, Q3 (both heads will be provide by Sharpy)
16 fasteddie 50, 1.00, Q3 and 50, 1.25, Q3
17 Trashman 75, 1.50, Q3
18 kazu 50, 1.25, Q3
19 Carpe Diem 50, 1.25, Q3 Cancelled
20 masakame 25, 1.50, Q3
21 iocheretyanny 50, 1.25, R2
22 Miciobigio 50, 1.50, Q3
23 Luff 50, 1.00 Q4, and a second light Q5+
24 AndyTiedye 50, 0.75, Q3
25 AuroraLite 50, 1.00, P3 or Q3 - Cancelled
26 Scottiver 2 lights both 2 stage 50, 1.25 watts (one head and one complete), will decide on emitter later
27 TENMMIKE 25, 1.00, Q3 or most premium for 4 of the same (may want to be
moved down on the list)
28 mcrich 50, 1.25, Will probably wait to get an R bin depending on if the price structure or options have changed.
29 MrMimizu 50, 1.25, Q5+
30 ydna 50, 1.25, Q4 WH
31 Newf-llb 50, 1.25, Q3
32 drews1 50, 1.00, Q3
33 grift 50, 0.75, Q3 & 50, 1.00, Q3
34 FlashMike 50, 1.00, Q3
35 rob_e 50, 1.50, Q3 Cancelled
36 Codeman 25, 1.50, Q4 or better
37 LouRoy for 2, 50, 0.75, and 50, 1.25, Q4WH
38 d'mo 25, 1.50, Q3
39 Chao 50, 1.00, Q3
40 Roboholic 50, 1.50, Q3
41 UncleFester 25mA Low, 1.5W High, Highest flux bin available R(x). Tint not critical.
42 Nuutaro 75, 1.50, Q3
43 VerbalK 75, 1.25, Q3
44 LEDninja 50, 0.75, Q4 WH
45 lightrod 50, 1.25, R2
46 FsTop 25, 1.25, Cancelled
47 bwm R2 WD 3/4 watt, 25ma low
48 Justone 50, 1.25, Q3
49 CodeOfLight Q4 WH, .25 and 1.25 watt
50 ProofTech Cancelled
51 Varriano 1.5 watt Best available
52 bexamous 50, 1.25, P4
53 dtlent 50, 0.75, P4 (head only) and 75, 1.25, Q3 (head w/ body)
54 daz 75, 1.25, Q3
55 Straightedge cancelled
56 Bobdrus 75, 1.25, Q3
57 vetkaw63 50, 1.25, Q3
58 ScarabDrowner 50, 1.00, Q3
59 eltel999 50, 1.25, R2
60 Jeweler 75, 1.50, Q5/R2
61 BVH .50 & 1.50. Q4 Head only
62 aiouem 50, 1.00, Q4 possibly a Q5/R2
63 pryan 25, 1.25, Q3
64 Amorphous 75, 0.75, P4 for 2 ( now )
65 Amorphous 75, 1.25, Q3 for 2 ( when available )
66 esunnycpf 50, 0.75, Q3
67 liteMANIAC 50, 0.75, Q3
68 pinepoint ?
69 Kevski 50, 1.00, Qx
70 blitzlicht65 50, 1.25, Q4 WH
71 alanhuth 25, 1.25, Q3
72 iNDiGLo 25, 1.50, Q3
73 JnC 50, 1.25, Q3
74 tuna 50, 1.25, Q3
75 stevevh 25, 1.00, P4
76 jefft 50, 1.25, Q5/R2
77 DaveNagy 50, 1.50, Q5/R2
78 Siegfried 25, 1.00, Q3
79 jki 50, 1.00, Q3 for 2
80 mudman cj 50mA, 1.5W, will provide emitter
81 tsask ?, 0.75, Q3
82 pdm 50 ,1.50, P4
83 frankr 25, 1.50, best bin available (R2 or better)
84 carlsjrman 25, 1.25, P4
85 Zionxem 50, 1.25, P4 or best available
86 svolich 50, 1.25, Q3
87 AustinEd 50, 1.25, P4
88 RIDE 50, 1.25, Q3 or best available.
89 JohnnyDeep 50, 1.25, Q3
90 Clickie 25, 1.00, P4 and a Lux mod on provided Arc
91 cpfx 50, .75, Q3
92 cocoa 50, 1.25, Q3
93 Koz99 50, 1.25, Q3
94 tsask ?, 0.75, Q3
95 Bright 50, 1.00, Best bin available
96 Lenny 50, 1.25, Q3
97 Navistar 75, 1.00, Q3
98 DrizzitT Cancelled
99 Gypsy 50, 1.25, Q3
100 Per Arne atest brightness bin available with no artifacts (ie, no yellow rings) - Q5 / R2 ??, one stage and head only. Will be using AAA lithium battery only
101 copykat 25, 1.50, Q4
102 kry81 75, 1.50, Q3
103 dansperry 50, 1.00, best bin available at build time
104 gswitter 50, 1.25, latest bin available (Tint at build time)
105 kashmir 50, 1.25 (if available), best bin available at build time
106 millerje 50, 1.50, Q3
107 gefff 50, 1.25, Best Available
108 rdh226 Will look at availability at build time (I have three unused Arc AAAs I can provide for upgrade.)
109 Daekar 25, 0.75, Q5/R2
110 Ozniot 25mA /.75W With a warmer tint.
111 Ned 50, 1.00, Q3
112 wuhair 50, 1.00, Q3 (WD)
113 GVS Lakers Latest bin - Will spec at build time
114 Gointothelight 25, 0.75, P4 (WD)
115 zumac99 50, 0.75, Warm White Q5 or better
116 racer7 50, 1.00, P4 (WD)
117 Pyros 25/1.50 (or 25/1.25 if possible)
118 ananddev 1 - 50mA 1.25W p4 (is WD the whitest?), 1 - 50mA 1.25W Q3 (When they become available)
119 Rustrel 50, 1.25, Q3
120 Freyth 75, 1.25, Q3
121 yoyoteen 50, 0.75 Q4 WH COMPLETE LIGHT
122 AustinEd 5mA?, 1.25 best Cree available, white XO tint
123 Austin 50, 1.25 Q3
124 FRANKVZ 50, 1.00 q4 possibly Q5/R2
xxx WTH Cancelled
125 err0r Q4 ,WD tint is preferred but will
accept WH. Low drive 50 mA, high level 1W
126 slaps 25, .75 best bin available - Q5/R2/R4...
127 THE_dAY 25, .75 best bin available - Q5/R2
128 GregY 25, .75 best bin available at build time
xxx Kraid Cancelled
129 xoltri 50, .75 ,2 LIGHTS best bin available
130 DarthLumen 2 LIGHTS, both single stage 50mA
xxx Nuggett Cancelled
131 Dizos 50, 1.25 Q5/R2 - best available
132 dd61999 50, 1.25 Q5
133 yaesumofo 25 / 1.5, best bin available
134 bfly 50, 1.00 best bin available
135 crazyglockman 25, 1.5 Q5 or best available
136 Illumination, 50mA,1.25w, Will specify bins
137 Steelbeach 25, 1.25 - best bin available
138 Panzergrennie Q3; 1,5 W; 50mA.
139 alex in germany Q3 or if possible Q5 Cree, 2 Stage with 25mA for Low, and 3/4 watt =240mA for high
140 gloworm Q3 (or better) 50ma low 1.0 Watt high
141 craigberesh Q5 Cree or best bin available, 50ma, 1W
142 Nebula 3/4 watt, 50 mA . Light Supplied.
143 colossus Q5 1.00 watt / 50 mA Old style light supplied?
144 mspeterson Q5 or better, will pick levels later
145 white light Q5 or better with 2 stage 50ma /1 watt
146 MrBadExample Will request specs later.
147 Lumenz 50/1.00 Cancelled
148 Spiderhole Will request specs nearer to build time
149 DarthChicken 25 low, 1.0 high, best available bin
150 Tyler2006 25 low, 1.5 high, Q5
151 adamlau 25 low ? high customer -supplied R2
152 hayhay 1 watt 50mA 2 stage with best bin available
153 future prius 50mA, 1W, Q5 or better.
154 HoopleHead 25mA, 1.00, Q5 Cancelled
155 ThomasEdison No specs given
156 neophyte340 no specs given
157 randyo , Q4 first, 50, 1.25, Q4 WH. Then another light with best available bin.
158 Midnightrun 25 low and 3/4 high with latest bin available
159 MKLight 1 watt, P4, with the low at 25, and possibly a Q5/R2
160 ptirmal premium bin 25ma/1.25A
161 jwrickert to be decided
162 stang68 Single stage 3/4 watt. Best bin you have on hand
Updated to post #241.
gg
