You keen guys make me smile. You haven't even seen it yet!
Here comes teaser number 4:
[Geek Warning]
The V3 has a microcontroller which can be reprogrammed by the owner. This means you can connect it to your computer and download a new UI if you don't like the one you selected when you bought it.
Maybe you thought you wanted 4 modes but then realise you hate the 2nd lowest one. --> Just plug it in and download a 3-mode UI!
Or you wish the lowest mode was much lower. --> Plug it in and download a UI with an ultra-low mode.
Want to use single-clicks to turn it on, but double-clicks to turn it off? --> ... you get the idea...
Want to add a strobe?
Want ramping instead of modes?
Want one of the modes to be a clock?
Want to make the battery indicator have 10 levels instead of 5?
Want a timer which lets you choose a number of minutes or hours and then flashes when the time is up?
Want one mode to be a momentary-on to use like a flashlight?
Want to record a message in Morse code then replay it over and over until the battery runs out?
... There's one switch and 3 LEDs. After that it's up to you to use your imagination.
There are 2 catches:
1. You do need an extra bit of hardware. I use a simple AVRISP MKII which cost me about $30. This goes between your USB port and the V3. Setting it up will be a bit tricky the first time but I'll give instructions. If you can set up a printer, an internet connection or a router, then you can set this thing up pretty easily.
2. Not everyone knows how to program a microcontroller. If you don't want to learn, then you'll need to rely on other people writing the software. I'll host anything that people want to write and upload. Hopefully between me and any other geeks out there we'll be able to build up a database of UIs.
... Sorry, but the GPS, touch screen, wireless and HD video camera will not be available until the V5.:nana:
