hi Der,
a fast question:
I was so impatient to try your driver that i used the p7 from my mte flashlight (it is taking ages for the p7s to arrive). I used 7.2volts li-ions (2s3p). I connected the driver as you indicate and a tester to measure the amps in serial with the p7. Everything ok in the pot-minimum. As a turned the pot on, the p7 started to flash (I even like that for a bicycle set up). The maximum that the p7 would take was about 1.93Amps at the maximum pot-turn. At some point, the p7 stop woking. I'm afraid I have fried it!! I thought a p7 will always reach 2.8amps at its vf. that's why I never checked the voltage I was puting in the p7, I thought it was safe because not crossing 2.8amps means not crossing the vf. Anyway 4.2volts wouldn't fried a p7 I thought too. It is possible that this p7 could take less that 2.8amps at its right vf, being in this case maybe low? (DD from a li-ion it would only take 1.5amps). I am a bit confused.
cheers,
Javi
