IlluminatedOne
I opened my light up and tooks some pics
bad news, light is dead, but before it died i got some data.
charger shuts off completely after it beeps, as i put new batteries charge time didn't change(about 1-1.5hr), so i suspect, at charging current of .5 amp, it filled aa only to 1\3 capacity, on high it ran about 1 hour, output of the power brick was 12v .5 amp, i,m not sure if i used different brick with differen current, charging current would be the same as brick's out.
i accidentally touched circuit board, and right away considarable amout of smoke, after that light wouldn't turn on. so board is fried, emitter is fine, so i cut it off, might use it someday for a build.
it is metal, light one, not sure if it is aluminium, might be something else
Newbie with a newb question here. I just got one of these and already lost the manual. Should this battery be allowed to go totally dead before charging, or can it be recharged at any time. Is there a danger of over-charging? Basically, how do I handle recharge to keep the light happy? Thanks in advance!
Welcome to CPF, woof
You asked in the correct place. I'm a little surprised you have not yet received a reply, but I hope someone will be along soon to help you.
I don't know the light myself, but as a rule you should not allow any battery to go dead before recharging it. Certainly in the short term, you will do less damage if you top it up whenever it gets to say 50%.
As to the manual, have you checked to see if you can download it online? Many manufacturers post their manuals online now.
Woof, based on what I have gathered in the batteries subforum here from the experts:
- NiMh don't like being overdischarged and can suffer damage if they are. It's best not to run them all the way to dead.
- Ever so often a relatively full discharge can be beneficial. Call that a little before the light is dead.
- You won't really cause serious issues if you simply use them and recharge after a partial discharge.
ps I didn't see a batteries subforum?
Hi woof, here's a link to the batteries sub-forum. Plenty of good info there.
BTW, how do you like the Stanley spotlight so far?
JB
