precisionworks
Received this from Mattaus by email & thought it may be of general interest to V10R owners:
A look at Mac's EDC shows the design Mattaus is looking for:
Shallow grooves like those can be cut but a "form tool" will have to be ground so that each groove has a 45° shoulder where the groove meets the raised section. Not too big a deal.
The grooves need to stay shallow & I'll have to measure the V10R tube to see how deep they can go. Even though the tube is almost 2.5mm thick a groove depth of 0.5mm on the radius leaves the tube at just 1.5mm thick. Probably thick enough but Mattaus will have to decide this.
The bevels on both ends of the battery tube are easy enough to do. This reminds me of the American fast food chain Burger King:
:nana:
To summarize:
- I'd like the handle section smoothed flat so that it has a Mac's EDC look about it.
- Is there anyway to create some grooving to make it less plain? Again Mac's EDC-ish...such a simple and clean design those lights! Nothing substantial - just something to break it up a bit, or is that really too difficult to do on this light?
- On the V10r Ti you have used as your experiment you've beveled the edge of the battery tube that connects to the head of the light so it's not just a sudden right angle from handle to head. Can this be done on both ends of the tube (so the start of the tail cap as well)? Or is it only feasible on the head end? Obviously the angle of the bevel needs to match on both ends otherwise it would look a bit 'off'.
:nana:
