The eb1 tactical tail cap won't work with your light. The tactical version has a different bodyI have the EB1 backup with the clicky tailcap. I want to get a momentary/twist cap for it. Anyone know where I can get one?
Are you sure?
I thought the EB1 tactical head and tailcap were different from the clicky but the body was the same.
And, are we talking about the 200 lumen EB1, not the newer 300 lumen model? And, you have the shrouded and unshrouded clickies in the early versions of the light.
I've certainly confused myself on this issue before. :thinking:
Actually you may be correct. Remembering now that I had tested with the E1L-A tailcap and that tailcap only had about half the threading (not enough to make contact) so it may work but will likely have the same result as cycling through the momentary function as the clicky - high - low back to high low.Are you sure?
