flashlight
Gotta to get me one of these.
Open your eyes, squint carefully, and then look again.What??? I don't see any difference!
Yes.You guys are just leaving the diffuser dome completely off when you add an optic, yes?
Yes, I used a little clear silicone on the black base of the LED around the "gummy" dome and stuck the optic in it and then tried to center the LED and let it dry. Nothing covers it and nothing supports it.Figuring out how to glue the optic on, and nothing else supports it or covers it, yes?
PhotonFanatic has the Khatod optics.I assume that the diffuser wouldn't fit over the optic anyway. I'm up to my eyeballs in modified lanterns, so haven't had the inspiration to mod these yet! Lazy me.
Have emitters...Must find optics...
I've decided to stick to the SSC P4's and the Khatod's. I haven't seen any other optics for SSC's, and I'm not sure a Cree optic will work very well on them.I've just got some of Brum's LC-1 Cree optics -going to give those a go soon.
I haven't been messing with the diffuser holder at all. I put the optic on after the diffuser holder is in place. I realize I can't take it apart in the future, without taking the optic off and maybe damaging the LED because the optic is larger than the opening in the diffuser holder, but that's OK. The only time I figure I might need to take it apart is if I were to upgrade the LEDs again in which case it won't really matter.If you were worried about it falling off -you could use the optic holder.Just have to open up the reflector/diffuser holder to accept it.EDIT (that's if your optic comes with a holder!!)
I haven't tested anything. Runtime should be the same as the stock light. It should also run a slight bit cooler than stock since more of the electrical power going to the LED is turned into light instead of heat. oo:Have you checked run times for the mod on low and high? And what about heat on high for extended run times?
