That is right, there is no real concern with regular NiMH AAA batteries. It is just 10440 you have to watch out for.. So despite Sysmax not recommending it there should be no problem charging single Eneloop AAA in i4 v2 or am I missing something?
Hmmm, seems to be "normal" - I get 5.33V when the charger is plugged in but no cell is in the slot. :shrug:I recently purchased the Intellicharger and took a DVM reading on the positive and negative contacts. The reading I get is 5.2v. My other solarforce charger gives me 4.20v. Is this normal?
No, it is just a straight-forward charger.How does this charger compare to a Maha if we are only talking about recharging Nimh AA's. Does it do any conditioning, etc.? Thanks
Quoted from the review:Can anyone confirm the charger doesnt trickle charge towards the end as i need to charge unprotected LG 3100 batts
It is certainly safe to leave the cells for a period of time once fully charged (as this is not a so-called "trickle charger", that would slowly cook them). But I wouldn't never recommend leaving cells in a charger for more than a few hours - they should be pulled once ready. You shouldn't leave any charging system plugged in for days at a time - they should always be monitored, and not left unattended if you can help it.My one remaining question is it safe to leave the charger plugged in with fully charged batteries?
I have read the discharge of Eagletac 18650 Li-ion is 10% or more; is it safe to leave a fully charged Eagletac 18650 in a plugged in Nitecore i4 version2 for 30 days?
There is certainly no reason to leave them plugged in. In terms of self-discharge, it is fairly low on Li-ion (compared to other types of non-Li chemistries). And since this isn't a trickle-charger, leaving them plugged in will not keep them "topped up" anyway (i.e. the uA current is too low).
Also, you should never leave batteries in a charger that is unplugged from a wall. Keep in mind that anything that is set-up to charge a cell can also discharge it. I've seen batteries left in an unplugged charger drain more quickly. Just remove them once ready and store them somewhere safe, and you should be fine.
Excellent review and great shots mate. Thanks.
I have one question though. Does this charger have the ability to discharge cells? I do not see this option mentioned though you said it can "discharge" cells like you maha charger @ 1830MAH??
