Markcm
I can't resist but to put in my two cents
I haven't tested anyone else's cells myself (I could be wrong) but I will make an educated guess that at this time NO manufacturer in China including the manufacturer of my cells at www.e-lectronics.net is anywhere near 900mAh on a rechargeable IC reduced 3 volt cell.
The IC in these cells takes up about 6mm which is about 18% of a standard CR123 and don't forget the small energy loss from dropping voltage through an IC; I could be wrong but 900mAh just sounds way higher than technology offers today. And believe me when I say that you can have anything you want printed on a battery from China, based on conversations I have had with Chinese manufacturers I believe they get caught up in marketing trying to out do the last highest capacity "rating" with no regards to actual performance. For instance, I see a lot of retailers who advertise 1000 recharge cycles, I'm admittedly not a battery chemist but I don't believe many standard grade normal use Li-ion batteries are going to make it past 500 cycles and be worth using anymore(correct me if I'm wrong here). I am trying to explain to them that brand recognition of a quality well represented product is worth many times more than a one-off label claiming high capacity....sooner or later people test products and demystify false claims. This is a whole new theory to the Chinese manufacturers I have talked with. Don't get me wrong, some of their product is very good, I guess determining which ones is our job here at CPF.
I personally believe in representing these cells exactly for what they are, I provide the best data of which I have personally collected and that shared by CPF'rs. You can see plotted performance of e-lectronics version of IC reduced versus a standard RCR123 HERE The best I can tell is that 600mAh is a good true value for these Chinese RCR123 3 volt IC reduced cells.
I don't have all the answers about these cells but I'll share the ones I do.
Does anyone have a set of these and a Maha 777 battery analyzer? I'd be interested to know what the capacity is too.....I'm guessing ~600
Okay, maybe that was my 3 cents worth :laughing:
-Markcm
-Markcm
