Of course this could just be a glitch -
so I've put that AW IMR 16340 back in for another Test cycle in another slot -
while I am testing a TrustFire IMR16340 in the slot that gave 1028mAh.
Will report when those are complete.
Try checking the battery in another slot and see if it gives the same result again.
Exactly what I was thinking - might be a problem with the particular slot as opposed to the battery, or the charger as a whole.
Thank you gentlemen for the advice - as you see we are thinking along the same lines.
These were the measurements that I got overnight:
That AW IMR16340, which got a reading of 1028mAh in Slot #1, is now in Slot #4 and its measurement is now 544mAh -
which is a much more realistic reading.
BUT the TrustFire IMR16340 that I did a Test Mode in Slot #1 at the same time gives a measurement of 1099mAh!!!! simply not realistic or "sensible" -
I think this shows there is a problem with Slot #1 on my brand new only just received Opus BT-C3100v2.1.
So I guess with the bad behavior of Slot #1 on my brand new just received Opus BT-C3100v2.1 -
I'll be contacting Gearbest.com to see about addressing the issue.
I had also said about Slot #1:
I had already used that slot to test an old unprotected 16340 and that was 543mAh -
so that slot seems "sensible"
That old unprotected LIR 123A/16340 is now in Slot #3 -
and its reading in that slot is now 156mAh!
So the so-called "sensible" reading of 543mAh that I got in Slot #1 was also wrong, and WAY over capacity -
it seems that that old LIR 123A/16340 is at the end of its life-cycle.
Just out of interest Slot #2 showing the -- -- mAh - actually had a reading (I can't remember exactly but it was in the region of 2-3XXmAh)
as I was just about to take the photo - setting the lights and and my camera -
the reading changed to -- --mAh and indicating it was charging.
My uneducated take is that the voltage had dropped below 4.0V and the charger decided to charge it back up to 4.2V
as per manual:
then went back into the Test Mode and was discharging the battery (as I took the pic - that's why it says Discharge in Slot #2)
Literally right after I removed the other 3 batteries - that slot gave a reading - so it was only a matter of minutes definitely <20mins
cough! - I think that battery is on its last legs......
Thanks for the help and suggestions so far.
