Ok sorry been a bit busy to respond.... so here we go.
Regarding the stones: Well we'll have 2 versions - one with / one without.. question is AL or TI for the non stone version... price difference is probably around $200 for the AL and $300+ for the TI.
Regarding being affraid or use it too hard... : Well this light is actually very very small... so the zoom pictures make it look larger...also they are recessed where you can't really damage them.
LedLenser: Well it's a difference whether you just drill some holes into the side with no real reflector or optics in the light... just flood, or whether you combine optics with a fairly challenging way of setting the sapphires (windows) so that they are back lighted and make it all watertight. If they patented their holes - I am pretty certain that we don't violate their patent since we don't have holes but sapphires there....it's quite a bit different... whatever it is if we get the patent than we're fine. If we don't we'll know.
Also the size, number of holes, look etc. are all very different.
Practical Use: Well if you're changing a tire at night... having the sapphire is a safety feature where traffic can see you much better. Unless you're in a tactical situation having the sapphires there is an advantage and important feature. Besides you don't lose any light - since we're using optics. Which brings us to the next topic
Reflector vs optics: Well I still need to see a reflector with better throw than the optics has we're using - than we would use a reflector for the non bling version. Yes you might get less Lumen with optics but perceived brightness (hotspot brightness) is Lux not Lumen. So show me a same diameter size reflector with better throw. I got quite a few examples of that optic outthrowing other reflectors and optic.
Sasha/Naming: Location of the thread.. Sorry my fault... it was pretty late when I started that thread (at least in my terms with a newborn 9pm is very late)... thanks for moving it. Yeah the name is a bit of a challenge.. this EOS goddess is pretty popular with products and trademarks... there is also a headlight called EOS... if we call it the Lumencraft EOS - so with company name it is fine...
Brightness adjustment not in the back: Well there are a couple issues with that. First I think it is the easiest one hand use interface. Every time you have a push button in the back you need to do a tactical hold anyway if you want it to turn on. Now with the EOS if we move the brightness adjustment to the front it would be the same interface as the Titan (if you use the rotation to turn the light off). But I find that most people use the clicky in the back for on and off rather than the knob, in which case the design makes more sense.
Generally it is possible to move the brightness adjustment, however the light would have to be longer, or a bit thicker which we rather want to avoid. Building a light that pretty much is the same size as the titan but add a full clicky, and use a 123 instead of a CR2 trust me there is not much material left anywhere to move anything around - every bit of space is used. After having used the GatLight now for a couple of months, I think most people leave the brightness adjusted to whatever the main use is (night stand light at very low level, outdoor light high level)... than they just use the clicky in the back for on and off.
Long lines along the body:
Well generally anything is possible - lines, swirls, hex patterns, helix etc. However we'd like to keep it very classy... make a suggestion and we can try to model it up in CAD. One more thing whatever we do there it can't be very deep... just the same. Another option would be add a pattern and fill it with silver... my TI wedding ring has that... and it looks kind of cool contrast silver/Titanium.
Holes a waste of light: well it has to do with my reflector/optics comment above. I don't think there is a better reflector/optics out there with more throw with a p4 than what we currently use. So based on that, the light coming out through the holes is not wasted. If there are no holes the light will stay inside of the cylinder and be wasted there - optics are 85% efficient, and we basically use the remaining 15% to illuminate the sapphires. A good perfect reflector (and most do not fall in this category) is 95% however they are inferior in focusing light if you go for throw (if you compare with a same size model). You get more lumen but less lux - and lux is what people perceive as how bright a flashlight is.
EOS and models: Ok let's see if I can convince a model.....so standby..
