mobile1
Galvanic...: I agree with you somewhat - when the light is held horizontally , if it's vertical I think it looks ok. The problem with making it more balanced is that it means adding weight and length, or removing the clicky. Regarding the knurl, its a question between look and function. The rough knurl is awesome to hold (same as with the gat) and operate.. the v2 had a thinner knurl and it's more slippery...
cue0003:
1) Heatsinking: well we're the only ones (I am aware off) that is using fairly thick solid COPPER CORE LED circuit boards. However the light is pretty tiny and it heats up quite a bit in the front - can still be held safely in the back though. Right now max is set to 1000mA (when used with rcr123) which is a bit high for continuous on.. however as with the Gat since it's using a very very smooth brightness control one can turn it down.
We will do the same as with the Gat and officially specify it for use with a primary lithium battery, as with those the max mA is 600mA - which is perfectly fine from a thermal point of view. For those who want a bit of extra ooomph... they can use a 3.6V and get the 1000mA - but they have to turn it down when it gets too warm.
2) Grip: with the stripes the grip is actually fairly good... and brightness adjustment is easy with one hand.
3) Regulation: Yes same as the GatLight - regulated on all levels - so buck boost chip - battery is being drained to 1.5V. When set to max it will regulate max brightness as long as possible after that it will pull whatever the battery can deliver (decreasing)... than it will go into a strobe mode (when it's being left to max) for a little while followed by an hour of low still usable ligth.
4) Runtimes: With a (primary lithium 123)battery you'll get about 1h runtime at 600mA light. And about 10 days at the lowest level.
5) Rechargeables: Officially its for use with primaries. However you can use protected 3.6V rechargeables. WE don't specify it for those since it's too hard to explain to your regular user what a protected cell is. There are many MFG's out there that sell protected batteries that in fact are not. So for liability reasons we spec it for use with 123's. Also when you pop in a 3.6V the max. level is 1000mA which gives you some extra brightness at max but also a lot less runtime. One thing though batteries get drained to 1.5V also rechargeables... so you can't deplete them or the rechargeables will have a very short life.
6) Upgradablity: YES - like the GatLight it is upgradable with newer Luxeon III type or Seoul P4 type LEDs provided they use the same optical characteristics which they tend to.
7) Momentary Brightness: Set to whatever level the brightness knob is set to.
8) Brightness when light is turned on: Like with the GatLight the last setting when light is turned off - unless the knob got adjusted while the light was off.
9) Availability - well we're currently getting quotes in so it's hard to tell.. but the earliest would be before Christmas hopefully (delivery) - however for a lower number f.e. 50 units we might be faster...
10) Model - Yep she's a hottie and smart too :thumbsup:
cue0003:
