DisrupTer911
Do you think it's sealed enough to be usable in a torrential downpour?
I can't imagine in 2011 people are going out of their way wanting big bulky headlamps like this when there are efficient 1 cell lights. I could see if there was a runtime benefit that having a huge 4 cellpack hanging on the back of my headband digging into the back of my head and strands of wires hanging around and then a third top strap making me feel like a cyborg would have but as I posted there is no runtime benefit over something like a Zebralight. By the end of this month Zebralight will be offering the H600 a 1x18650 cell with runtime of 1920 hours or 80days!!!!! 500 lumens for 2.1 hours, 330 lumens for 3 hours and 200 lumens for 6 hours all on 1 cell (18650) and no weird battery packs and no tangling wires or bulky top head strap.
This is like comparing a moped to an RV for a cross country trip. You need a moped for best single person across city, while a Van is best for a cross country trip.
Similarly, you will never paint or high speed bike or dry wall or detail carpentry or do serious work with a weak cell, diffuse light. You will end up killing your self and doing inferior work. More lux also means more runtime, because you can use lower settings and still see. More flood also means reduced night vision and less ability to see.
I'm just perplexed people still WANT a bulky light like this in 2011. Do you guys not know about Zebralight?
you keep bringing up this Zebralight, so maybe i should give one a chance. can you recommend me one that can do the following:
i need a minimum of 130 lumens for 8 hours continuous use.
i need peak output that's close to 300 lumens and peak intensity that's close to 6000 cd on max.
i need it to throw 150 yards in a pinch.
i need it to run on AA batteries.
since i'll be wearing it on my climbing/caving helmet, weight isn't a real big issue, but front/rear balance is very important.
i look forward to trying a Zebralight that meets my needs.
Pretty sure a H51 with a lithium 14500 would do the trick and if not that then possibly their upcoming H-502 which will be even better than the previous H51. Win/win here as you're using less batterys (less waste to the environment if you are still using primaries and not NiMH recharageables) and getting the same performance with a 4-5x increase in efficiency and a lighter more streamlined (comfortable) headlamp. You'll thank me later.
Cyamn down, cyamn down..... (mock Liverpudlian accent - might not make sense to US based CPFers)
I can see the shellsuit and curly hair as clear as day.Cyamn down, cyamn down..... (mock Liverpudlian accent - might not make sense to US based CPFers)
I'd second that.My comments would be that if your requirements are small, light-weight and single cell (but limited output and runtime) then Zebralight are excellent, if you need higher output for longer periods and the runtime only a multi-cell light can give, then headlights like the HP11 are excellent.
uk_caver;3737715 Excellent review - if I didn't have the niche already covered sufficiently for my needs said:Got my hp11 ordered and in the air. I finally felt I hadn't upgraded recently enough. I did just make a xpe r2 fl into a hl. I will need to see lux at 133 to determine if it is suitable for me.
I really would like to see a xml u3 bin, with some throw (possibly dedomed). But I am guessing 3 years will pass before this is offered.
I wish Cree made an XM-L equivalent, but with a separately addressable inner core. It'd be great to have a headtorch with an electrically-controlled zoom for the spot beam, so you could light distant objects with a narrow beam, saving a lot of power/heat for a given intensity of illumination, but have a wide beam for closer work like trail following where less intensity would often be needed, without the complication and bulk of multiple LEDs/optics or mechanical zooming.I really would like to see a xml u3 bin, with some throw (possibly dedomed). But I am guessing 3 years will pass before this is offered.
Cons:
3. Center strap is too short!!!! Most users will not realize this, and consider the HP11 uncomfortable. :-( This is easy to modify with some Walmart elastic, scissors and thread. Or Just use strap from another light. Lengthen the center strap, and it becomes nearly as comfortable/balances as the Remington (tad heavier.) or any 3 aaa hl.
4. The driver did crash two of the 4 AA cells after my first 1.5 hours of use. So, as very first my light with a fully regulated 4 cell driver, I am still evaluating to see how picky it will be on cell. {I have returned 2 AA [brick and mortar] lights where every 15 minutes I needed to change cells, since the driver was so picky.}
