Wow,
Quite a bit of interest here!
I'd like to throw in some comments observations here.
If you can't find what you want and can't talk someone into making it, your left with making it or getting it made yourself. There are certain features about the McLux that we liked and wanted in our own EDC's and we couldn't talk any of the *real* flashlight manufacturers into incorporating these ideas into their lines. As flashaholics, we wanted some simple mod building blocks so we could mix and match and mess around.
There were a couple key and basic criteria that were addressed in the design and requirements of the limited production run of the parts:
</font><ul type="square">[*]<font size="2" face="Verdana, Arial">1 watt (with option of 5W) Luxeon light source</font>[/list]<font size="2" face="Verdana, Arial"></font><ul type="square">[*]<font size="2" face="Verdana, Arial">Beam shape options: flood or optics</font>[/list]<font size="2" face="Verdana, Arial"></font><ul type="square">[*]<font size="2" face="Verdana, Arial">simple and solid heat sink via integrated sink bulkhead</font>[/list]<font size="2" face="Verdana, Arial"></font><ul type="square">[*]<font size="2" face="Verdana, Arial">significant mass and surface area for thermal relief</font>[/list]<font size="2" face="Verdana, Arial"></font><ul type="square">[*]<font size="2" face="Verdana, Arial">simple and direct electrical paths for ground and positive</font>[/list]<font size="2" face="Verdana, Arial"></font><ul type="square">[*]<font size="2" face="Verdana, Arial">replaceable and accessible components</font>[/list]<font size="2" face="Verdana, Arial"></font><ul type="square">[*]<font size="2" face="Verdana, Arial">bezel down carry</font>[/list]<font size="2" face="Verdana, Arial"></font><ul type="square">[*]<font size="2" face="Verdana, Arial">multiple lanyard, tether and mounting options</font>[/list]<font size="2" face="Verdana, Arial"></font><ul type="square">[*]<font size="2" face="Verdana, Arial">compatability with other existing flashlight components; head and power pak</font>[/list]<font size="2" face="Verdana, Arial"></font><ul type="square">[*]<font size="2" face="Verdana, Arial">guarded tail switch with stand up feature</font>[/list]<font size="2" face="Verdana, Arial"></font><ul type="square">[*]<font size="2" face="Verdana, Arial">mineral glass or sapphire crystal lens options
- modularity where possible</font>
<font size="2" face="Verdana, Arial"></font><ul type="square">[*]<font size="2" face="Verdana, Arial">stout material construction with components well protected from shock, environment and rough use (utility over style)</font>[/list]<font size="2" face="Verdana, Arial">As someone pointed out above, We let the function dictate form on this light. Personally, although I don't care for the beam from the optics, we all agreed that having this option was important and we already had the McFlood which was designed as an option to the Lumiled optics. The McFlood sets this light aside from others. There are many professional and fine lights available using the Luxeons and stock optics but where the McLux has gone off on its own is as a feature rich task light for in close work and a variety of means of carry and deployment where hands free use is desired. This is not a tactical light; rather it's a work and task light. We wanted a state of the art, quality tool that would meet most of our typical needs and not necessarily have the "wow" factor of other lights we have acquired as flashaholics.
This was to be an EDC light.
Room has been provided in the electronics cavity for not only Wayne's current offering of Bad Boys and Mad Max's but for future wonders as well. At this point, we haven't a clue how this is going to pan out but we did get enough parts made so we can share some of them with our CPF friends.
I should also point out that the primary power source in consideration is a single 123 cell. Obviously the power pak length can be extended for multiple cells and other strategies. Leo had one drawing with I think 6 different lengths
To accommodate 2xA (Roger and his NiMH's
) or 2xAA or 3x123, Leo slipped some of the "Long Tails" in on us. I have already taken one of these and cut and rethreaded it to a 2x123 length so I could use a Copia 168b Li-Ion with a KL1 bezel.
We have kind of taken a "build your own to suit your needs" approach here since we certainly can't leave well enough alone and it looks like we're not alone in this!
It looks like we need to get more images available showing the components and possible assembly strategies. We can also try to document the various combinations of both the McLux components as well as the myriad of mixes with branded components.
- Don
