SilverFox
Hello Jar3ds,
Protected cells would work fine, but usually with protected cells you loose some of the capacity. Starting with only 330 mAh, the losses in capacity may be significant.
I never asked AW if these came in a protected form, so I don't know if they are even available.
Since the EOS is a regulated light and doesn't have a high current draw, I am not sure there would be an improvement using Lithium AAA's in the stock configuration. However, if you were going to store it in your car for emergency use, it would be a good choice.
I remember the original Alkaline cells seemed to last forever. After I ran them out, I switched to NiMh. I never had a problem with them, but I am diligent to re-charge often.
After using this modified EOS for a few days, I find that since I changed the optic, I find that I am using medium more than before at work. With the stock set up, I would switch the light to low and go. Now, with the wider beam, I can get by with low, but prefer medium.
However, I no longer need my diffuser to read a book. The low setting is just right.
I guess there are trade offs which ever way you go...
At any rate, using re-chargeable cells, I don't mind going up in power, I just have to re-charge a little more often.
Tom
Tom
