oh, also, I think all those tests are stupid also.
Cold Steel has a bad habit of making goofy vids to demo the knives.
Most any knife, even junk, can do what they demo.
Its just a matter of how long the edge holds up, and it the knife would break after Repeated abuse.
~John
Thank You! You raise an excellent point.
To: cutlerylover -
Those extreme tests seen in the CS "Proof" videos are used to help sell CS knives. The claims are that a ColdSteel knife can pass such "extreme testing." But, when an individual buys a CS knife and wants to put it to the same test that he saw it pass in the video; CS tells him, "Oh, that's abuse. It'll void the warranty."
What the Hell?...... Oh no, you can't have it both ways! You can't claim your products are good enough for use under extreme conditions when you're selling them, but then claim those exact same conditions are "abuse," after the product was purchased.
As far as the CS Trailmaster challenge goes, you're right! No other owner or CEO of a knife company is going to lower himself and get in the mud to play Mr. Thompson's game.
Here's the thing, that challenge was issued with regards to a Carbon V Trailmaster. (I think I've seen you on Bladeforums. You probably encountered the following).....
Someone bought a Trailmaster and had the steel analyzed. Turns out, Carbon V is a fairly well-known carbon steel. (I can't recall its official name now. Mostly because there are several numbers in the name). But it's not some sort of super alloy that only ColdSteel has access to. The heat treat on Carbon V blades used to be done by Camilus, before they went out of business.....
Do you honestly believe that a Custom blade from the forge of a Master bladesmith is not going to outperform a Trailmaster? Let's say the smith isn't good at heat treating, so he takes his blades to Paul Bos. When it comes to heat treats, good luck finding someone who could do a better job. Quite a few Production blades could pass the Challenge too. But why waste time even going for it? So you can prove that your product is better than one that has been hyped to a ridiculous degree? What's the point? (Other than entertainment value perhaps).
Cliff Stamp does a much more scientific job of extreme knife testing than Noss. A bit too scientific at times. But his torture tests are a bit more consistant.
