hivoltage
How does this compare to the Jetbeam RRT-3? Looking for something to outperform it. Thanks
I just got my TN30 and it has slight play either. But TN31 has slightly more play. I think it is normal for Thrunite. Hope that it is not because they didn't put some o-ring under it.There's a slight play in my TN30 so it's normal
Has anyone figured out why Thrunite rates the TN31 at only 75k cd BUT WITH A THROW of 700 meters?
All the third party tests put the throw in the 600+ M range, and ~ 115k-ish cd ranges.
ive wondered that since day 1 also teej...
just the opposite, as most manufactures would of changed it the very minute anybody with credentials, would of came up with higher numbers, like selfbuilt...
---------------------------------------------------------------------------------------------------Thanks for posting the review. I purchased the TN31 and I am very satisfied with it.
That would not be good - no problem on either my TN30 or TN31. Sounds like you are having a connection problem - I would clearn all contact surfaces and make sure all screws/threads are securely tightened. If you are unable to resolve the issue with this kind of preventive maintenance, I'd contact your dealer for assistance.Hi, for those owned TN31, any one facing difficult switch on problem, need to hit the flashlight to get it on?
Oh, and :welcome:
Hi,
1 The manufacterer says only 75000 cd beam peak intensity, but 700 metres beam distance is more , over 110 000 cd.
I not understand this. Can you explain this?
2 What if you put the Tn31 on your bicycle, with turbo mode on, and you shine the lamp straight forwards into the eyes of the oncomming traffic?
3 There is another TN31, and more lumens, and more beam distance, do you know about that? Why you not have the most powerfull one?
4 How bright does the 0,5 lumens ultra low mode on yout TN31 looks to you?
Remco
Their numbers are not consistent with ANSI FL-1 standard. I would recommend you rely on my actual testing results.1 The manufacterer says only 75000 cd beam peak intensity, but 700 metres beam distance is more , over 110 000 cd.I not understand this. Can you explain this?
Frankly, the TN31 is throwier than I would want for a bicycle, but I would recommend you angle it downward to so as not to blind oncoming traffic (same is true for any light).2 What if you put the Tn31 on your bicycle, with turbo mode on, and you shine the lamp straight forwards into the eyes of the oncomming traffic?
Because this review is 10 months old ...3 There is another TN31, and more lumens, and more beam distance, do you know about that? Why you not have the most powerfull one?
It's pretty dim.4 How bright does the 0,5 lumens ultra low mode on yout TN31 looks to you?
I guess I type slower than you do. :laughing:LOL
Its like an echo.
Thrunite has indicated they have some new lights they want me to review, but I'm not sure which models yet.
There are more flickering complaints on the TN31 (maybe because a lot more people bought it)
