ElectronGuru
Have the Triple H3 L/M/H Neutral gone on sale yet or have they already sold out?
The first LMH 219's are scheduled to land, tomorrow afternoon (PST)
Here are a full complement of beamshots. The H3 Nichia is in the bottom left corner.
Is that ~90 mins on HIGH w/ single 18650 3100mAh cell?
With a single lithium cell, It will run at approximately 75% output (800+ lumens) in this configuration.
These are not regulated on 1 cell
A single AW 18650 3100mAh cell will provide about 90 minutes of runtime
Tried mine yesterday (219 version). Got pretty hot and did not notice thermal regulation either.
I'm thinking that it just isn't getting hot enough. The surface of the light might get really hot, but it may be because heat is getting sinked out of the drop in away from the 1334 board. The battery stretch function certainly worked. I used the light for a while in my C2 with 2 x AW IMR18350's, and noticed it went from high into a low mode. Sure enough, I put the 18350's on my ZTS tester, and they were at 10%.
Did you notice and very slight "pulse" in output on your light about every 3 seconds?
Tom, Dan,
Concerning throw what is correct:
1. XPE > XPG > 219
Has anyone had a chance to try these? I received a V4 XP-E neutral yesterday, and have tried running it for 15 minutes in a bored 9p with 2 x AW 17500's to see if the thermal regulation would kick in. It didn't, but the light never got too hot to touch. The whole body of the light was very warm though. I did notice that the light wouldn't go into low mode when it was hot.
I know it's like asking how long is a piece of string, but how long would you normally run these before the thermal regulation kicks in? I'm in a room with an ambient tempreature of 20C.
I can replicate this behavior somewhat.
if I try to cycle the modes very quickly when the light is very hot, I do seem to lose low mode.
It will cycle through M,H,M,H,M,H
If I simply wait 1 second between modes, low mode is back and I can cycle through 3 modes fine.
It just takes a slightly longer pause between modes for it to function correctly when very hot.
I suspect that the electronics simply perform slightly different at this high temp.
Cheers Fellas!
There is a little Red LED that is mounted just next to one of the main LED's. I can see it come on when the light is on low mode if I look at it from the side. It seems to pulse on and off slowly. I never noticed this in my V3 version. According to the manual for 1334 boards, it means that the battery is fully discharged. This is intersting, as the 18650 battery I'm using at the moment is fully charged.
According to Moddoo's first post the function of the red led is different: "High-temperature warning is introduced in the stand-by mode (fast red-indicator blinking during which it's not recommended to touch the flashlight head)."
That is also mentioned in the manual. Fast bright flashing, hot bezel. Slow dim blinking, low power and unable to operate the light. Which is interesting, as the only time I see the slow blinking is when the light is operating.
You got a manual with yours?
I received my 219 HML a few days back and I am very pleased. There is a very significant difference between 1-cell and 2-cell with the H3 drop-in; much more so that with the L3 HML XPG neutral. The 219 H3 pulls about 2.4A (tailcap reading) on both 18650 single cell and 2 cells, so 2-cells is nearly double the power.
Really nice work on these drop-ins. I am continually impressed with the performance and improvements between versions. Well worth the money for a truly quality product.
