I guess I am the only one with questions. Is the color the only difference between choices? Because you mention UV stabilizer, GIDP and colors as ingredients for these lens caps which makes me wonder if these additives will impact on hardness/softness. Which lens cover will be the most durable? Will they be a friction fit or will they use an o-ring? I see a lot of pictures of the top of the lens cover but none of the portion that slips into the TRI-V itself. Thank you for all your hard work on this project.
The additives, other than an accelerant I use, do not really affect the hardness/softness of the rubber. As a general rule anything you add to the rubber is going to modify and maybe degrade the properties. That said with the exception of the GITDP everything is designed to be used as a "system" so I see no real reason to worry. The least durable would probably be the GITD version but that is just a guess. Even still unless you are really abusing it I see no reason to worry.
They are friction fit using primarily the ID of the aspheric to do the holding. I still need to get the caps over to fasteddie so he can verify that it works in the field before I go making all these caps. I need to stop fooling around with all these variants.
And on that note I'd like to mention that I am working on making some that increase the CRI of the light.
The caps look the same color as the high CRI phosphors you see in LEDs. I am using a phosphorescent red dye to boost the reds a bit. They are still setting up at the moment so I don't have any pictures yet.
I'll get pics of the backside up in a few minutes.
Quick question...
If one were to cut off the A cover, and only leave the Flood cover, would this stay on the light or would it be inclinded to fall off??
Reason, I would like one to protect the Flood light as a more permanent type, as the R & A lenses are the ones I use the most.
This would allow me to keep the bare LED covered for 99% of the time and keep the A available without removing the cover.
If this is the case, I want to order another cover that I can cut up. Can I add one more to my order & save shipping charges again?
No this will not be possible. The area around the flood does not have a complete circuit around the circumference and therefore has no way of applying any holding pressure. I did consider making a separate piece that would cover only the flood but not enough people seemed interested in that. You can of course add more to your order without being charged any more for shipping unless your order has already shipped which it most definitely has not. :thumbsup:
