For those with access to a lathe here is a easy way to mod a W200.
You need a Aluminium tube OD 22mm or more and ID about 18.5mm or enough to fit a 18650 cell. If you are running AA's you could probably use the original pill.
You will also need a P60 drop in from DX/KD. You should be able to use any P60 drop in you want. I used a XP-G for this one.
You need to machine off the taper behind the threads on the drop in.
Then machine a thread into one end of the tube (m20x1mm I think).
Machine the tube so it fits into the head (21mm) but has a lip at the bottom end.
Thread the drop in into the tube but leave some thread exposed.
Thread the reflector on to check it can screw all the way down. If needed you can cut a 1mm or 2 off the end of the reflector although I didnt have to.
Unscrew reflector and fit drop in into head and then screw reflector back on.
This modification was brought to you by the letters P and H and the number 40.
