vortechs
The thought did occur to me that the all-battery web site might be talking about a group of four 18650's with a single protection PCB, however the picture didn't show that and the description says "internal PCB", furthermore all of the statistics given, such as dimensions and capacity, are all obviously for a single 18650 rather than a group of four wired together.
However, the listing and description on the Battery Junction website (http://www.batteryjunction.com/186502200pcb.html), is more clearly a single 18650, since at Battery Junction you can order any quantity you want, rather than groups of four. Below is the Battery Junction listing for them (the formatting doesn't show up as well here as it does on the actual website). Note that this description is virtually identical to the one at all-battery, so it seems likely that they were both copied from the same source, probably data from the manufacturer. At least one thing in the description is incorrect, since the length of the cells is 65mm rather than 68+/- 0.2mm. This does raise the question of whether the missing 3mm is where the internal protection PCB is supposed to be and they somehow got left off of this batch, or perhaps the manufacturer shipped the wrong item. MattK (from Battery Junction) has been pretty good on the forums, so I'm sure he'll get things sorted out eventually.
Here is the description of the item on the Battery Junction website:
Li-Ion 18650 3.7V 2200 mAh rechargeable battery with protection PCB
Item#: 186502200pcb
Availability: Usually ships the next business day.
Price: $5.95
Enter Quantity:
Quantity Discounts![font=arial, helvetica]
1[/font][font=arial, helvetica] - 4[/font]
[font=arial, helvetica]$5.95 ea.[/font]
5[/font][font=arial, helvetica] - 19[/font]
[font=arial, helvetica]$5.65 ea.[/font][font=arial, helvetica]
20[/font][font=arial, helvetica] - 49[/font]
[font=arial, helvetica]$5.35 ea.[/font][font=arial, helvetica]
50[/font][font=arial, helvetica] +[/font]
[font=arial, helvetica]$5.05 ea.[/font]
FEATURES AND BENEFITS
Lithium Ion 18650 cylindrical rechargeable batteries
- 3.7V 2200mAh high capacity
- Higher energy density and lower weight than other types rechargeable batteries
- Manufactured under ISO9001-2000 to assure quality
- Internal PCB protects against under and over charging- low voltage 2.8, high voltage 4.2.
- Battery tested based on International Electrotechnical Commission (IEC) standard to ensure capacity, quality and life time
Applications:
- Building Laptop Battery
- Building portable power device needing high energy density and low wieght
Cautions:
- Use special caution when working with Li-ion cells, they are very sensitive to charging characteristics and may explode if mis-handled.
- Make sure user has enough knowledge on Li-Ion rechargeable batteries in charging, discharging and assembly before use.
- We are not resposible for any damage caused by misuse or mishandling of thses Li-Ion batteries
Product Specifications:
- Capacity* Nominal 2200 mAh, Minimum 2150 mAh
- Dimensions:
Diameter 18+/- 0.2 mm
Height 68+/- 0.2mm
- Weight (Typical) Approx. 46 g yes
- Nominal Voltage: Average 3.7V
- Cut-off Voltage: 3.0V
- Internal Impedance: less or equal to 180 milliohm (with PTC)
- Cycle Performance: 90% of initial capacity at 400 cycles
- Cycle life: > 500 cycles
- Charge: Current = 0.5C mA Voltage = 4.2 V End Current = 0.01 mA
- Discharge: Current = 0.5C mA End Voltage = 3.0V
- Max. Charging current: 1.5C ma
- Max. Discharging current 1.5C ma (for continuous discharge)[/font]
Item#: 186502200pcb
Price: $5.95
Enter Quantity:
Applications:
Cautions:
- Dimensions:
Height 68+/- 0.2mm
