Ake -
Got my bulbs on Thursday. Thanks to you and Lemlux!
Just for reference purposes: I ordered only the MiniMag 01121 lamps, and I tried plugging them in yesterday. After reading Lemlux's previous posts about installation difficulties I was a bit worried, but I didn't have any problems. Cut off a bit of the leads, folded them in two, and stuck them through the existing lamp socket of the MiniMag. I did stick a dowel into the MiniMag body to hold the switch in place during this installation, but other than that, I didn't do any modification. The leads seemed to be rigid enough span the small gap between the switch cover (the "do not remove" portion of the switch) and the actual sockets.
The actual performance, however, was somewhat disappointing. While the output was significantly greater than the stock MiniMag bulb, compared to the NexStar lamp, there was only the barest of improvement (freshly charged Nexcell 1800mAh NiMHs in each). Perhaps this has a lot to do with the reflector not being optimized for this larger lamp, since I also found that the beam quality was significantly worse than the NexStar lamp - huge hole in the center of the beam, and I could only eliminate this hole by focusing the beam down to a really tight spot. Comparing the two lamps (WA and NexStar) side by side in candle mode, the WA lamp seems to generate more light from a larger source, but the difference is not immediately obvious.
I'll play around with these lamps some more, but at this stage, I'd recommend the Brinkmann NexStars over them for anyone looking to improve their MiniMag quality. Cheaper, similar output, better beam quality, easier replacement, "spareable" (i.e., fits in the existing MiniMag spare compartment), and no lead/reflector manipulation required. Once I get around to ordering a Carley reflector I might change my mind, however (although I'm still surprised that the similarity in total light output between the two lamps - perhaps I need to work on the switch interface a little more for the WA bulb).
John
