Aloft
While building your own stove certainly has a strong appeal, for those of us that lack the necessary mechanical savvy, I highly recommend the "Clikstand". I keep it in a 0.9liter ti pot (not non-stick, you don't want to scratch that stuff!). The Clikstand uses the proven Trangia burner that has served Swedish Army soldiers for about a century, IIRC. It has the advantage of a screw top so you can save the fuel in the burner that has not burned for your next meal. I was very impressed by the Clikstand's quality and apparent durability.
Of course, you could also try the "real" Trangia Stoves, made by trangia.se ... they're not ultralight by any means, and they rattle around in a pack, but they're bombproof and virtually unaffected by wind. I did a little test with a half liter of water:
Tap water (approx 65F), Outside air temp 65F .... Boil in 8 minutes
Ice Water (approx 38F), Outside air temp 65F .... Boil in 8 minutes
Tap Water, Outside air temp 40F .... Boil in 8 minutes
Ice Water, Outside air temp 40F, wind about 12mph .... Boil in 8 minutes
Hmmm, no discernable pattern there! Not as impressive as a Jet Boil or some other fancy liquid fueled stove which claim a 90 second boil, but not as temperamental either; or as smelly or loud.
I usually light my Trangia burner with sparks from a swiss fire steel. I once put my burner in the freezer with a full fuel load for 3 weeks (don't forget to put the screw top on!). After getting its temperature down that much, it would NOT light with the firesteel, but still lit very easily with an open flame from a match. I did this to test the theory that alcohol stoves are unreliable in freezing temps ... theory apparently busted! Seems like a silly theory anyway, since they're used in Sweden all the time!
If you're not familiar with alcohol stoves, a word of caution. Their advantages of silent operation and almost invisible flame (especially in daylight) might make them ideal for Navy SEALS or Army Rangers, but if you have small kids around, be careful they don't knock it over ... the fuel will spill and catch nearby objects on fire.
