f22shift
i've always wanted to make one of those stove with the aluminum beer bottle(aka stadium bottle?)
i can never find it though..
Looking good TB... but what's with that huge pot and where's your Ti kettle?
Nice stoves Greenled and thanks for pics! The one on the right sure is a flame monster.
My most recent build is the Super Cat Stove. This is another super simple stove, consisting of 1x 85g aluminium cat food can and two rows of strategically placed holes around the sides. Out of the 3 stoves built so far this is the easiest. Unlike the other stoves this one doesn't require a pot stand, the billy sits directly on top of the can.
l
Isopropyl is alcohol and water, so the higher the %, the lower the amount of water you're trying to "burn" in your stove. Some stoves work fine on the better rubbing alcohol, but it tends to burn sooty and does not produce the heat of methanol.
Methanol (denatured alcohol) can be found in the paint section of hardware stores, or in the auto parts dept of store as YELLOW Heet. Make sure it's the yellow, only. It's much better than isopropyl, in my experience. I don't know why you had trouble. Perhaps you were using a design that has to be pre-heated? The Penny Stove, for example is a piece of cake to light, but it runs on denatured, not isopropyl.
All my best,
Dirty Bob
All my best,
Dirty Bob
Some alcohol stoves can't be lit at the jets until the alcohol inside is warm and producing vapors that can burn. (Liquid alcohol does NOT burn, it's the vaporized alcohol on top of the liquid that burns). These stoves have a small dish, tray, lip or other arrangement for a small amount of alcohol to heat the stove. I have a pressurized stove that works this way. You place a tiny amount of alcohol in the preheat lip at the base of the stove after fueling. You then light the preheat alcohol, which warms the sides of the stove. When vapors reach the jets, they light, and cooking continues as normal.I'm using denatured alcohol in my penny stove but it won't light, what do you mean by pre heated?
thanks for helping
