A MagTac is a thrower that uses 123 cells.
Trouble is, as things modernize for more brightness the industry is building lights to spread the beam more widely. You almost need to step back in time to find lights with a pencil beam. Like Gene Malkoffs M60T module or a Streamlight TL2 from circa 2014 for true pencil beam output.
Since alkalines are out, perhaps consider Powerex Imedion C cells in a Maglite ML50. Pricey going in for the fuel cells, but the XL50 has that classic Maglite adjustability. Using the medium (called low by Maglite) is plenty bright while conserving fuel. The low (called "eco" by Maglite) puts out a battery sipping 20 or so general use lumens and allows literally hundreds of hours of runtime.
I really like a 3C Maglite ML25 with Imedions. The package says 178 lumens, but the CD is over 12k, which indicates it's almost like having a snoot over the head. Pencil beam with a capital P. Pick the beam you like and turn it on/off via the tailcap. I also like the Coast HP7 fed by Eneloop Pro cells for zoomy purposes. I use both to light inside of pipes and manholes in the daytime.
