roadkill1109
- Joined
- Mar 11, 2011
- Messages
- 2,309
Perhaps, its safe to say, the BEST EDC, is the EDC you use the most.
-The Quark 1xAA X is still my top light: from ~200 hr runtimes to ~400 lumen highs (14500) with a 10 warranty and HQ/CS in the US.
where do you see that? This is only 100 lumens.
http://www.4sevens.com/product_info.php?products_id=1597
Note: There is now a step-down feature just after 3 mins runtime on max, designed to help limit thermal issues on extended runs. For the Q123-2 X, output drops from ~520 estimated lumens to ~400 estimated lumens, while the QAA-2 X drops from ~400 estimated lumens to ~300 estimated lumens. I put the higher lumen values in the table, as that is what I measured at exactly 3 mins into the run (i.e. just before the drop).
nitecore sens series imo are towards the top for sure
What did you use every day in your pocket, and why? Perhaps the best 2 or 3?
My two current faves for true, unobtrusive EDC are the HDS high CRI Twisty with clip and the Nichia 219 version of the Peak Logan QTC also with a clip. Both are relatively small, bright, well constructed and extremely reliable.
The Logan has the advantage of being slightly smaller, having the best tint and rendition of any LED light I've owned and features a nearly infinitely adjustable output range without the need for any electronics. The HDS, on the other hand, boasts a buttery smooth operation and an actual, meaningful water resistance rating.
