Currently EDC'ing the following lights:
1. Modified Sipik 58 AA sized budget zoomable. My "project light". I've modded this light and have more modifications planned (so far: emitter swapped to XML T6 neutral, driver swapped to 2.8 amp 8x7135, switch and switch boot swapped with spare from ShiningBeam S-mini, small reflector added, copper heatsinking added inside pill below emitter. Spacers added so pill sill ride slightly higher in body to get closer to lens, filed down top of pill and part of the body to allow the head to retract further back and the pill assembly to almost touch the lens, tailcap swapped for smoother one from Sipik 68, all anodozing removed with Greased lightning and external bare aluminum sanded and polished). Once more parts arrive I plan to replace my 3-mode driver with a custom programmed driver, and the switch with an electronic switch. Produces a wide floody spill with almost no rings and a slight hotspot. Able to zoom for medium range spot. Not great for long-range due to small aspheric and big XML though. Running on AW IMR 14500.
2. DQGIII AAA R4 - tiny backup light with beautiful beam pattern, nice tint and long runtime. Running on Energizer AAA.
3. Tiny white LED light built into mini victorinox swiss army knife. Gives new meaning to the word "dim".
Depending on what mood I'm in I might swap the Sipik 58 for my RRT-01 or TCR-01.
