357mag1
The neutral warm Tac 123x2 is my main house light.
FYI it is best to run an AW 17670 protected (same physical size as two123's) in the x2 and P3D. Two primaries can be a little mismatched in voltage. With Li-Ions you generally want to avoid using multiple cells in one light. The disparity in current discharge can cause problems. Added benefit one 17670 is cheaper than 2 RCR123's. IMHO two 17670's and two 123's would set you up nicely. You really have to have an extended use session to deplete a 17670. Having six primaries for back-up's on hand would complete your power needs.
The above is definitely an option but be aware 4Sevens tells me the Quark 123x2 will not stay in regulation using a single 17670. Tailcap current on my samples measures 920ma for the 17670 and about 450ma for the AW RCR123s meaning runtime difference would be negligible.
My PD30 and several 123x2 Quarks are a very tight fit with the 17670 AW protected batteries. You have to press them in and then take the light apart at the head to press them back out. On several they will not go in without removing the sticker on the battery and are still very tight.
Using the longer batteries would require you to step up to the WF-139 for about $5 more. You would need aluminum spacers to be able to charge RCR123 batteries in the WF-139 which Lighthound sells for $1.99 each.
