Vaping can get crazy, some use such low ohm coils in their builds..............basically they are shorting the battery/s out. Just checked now and my mod is using 6.8a through 2x 20700 cells(not much load for 3s or so at a time). I dont get the crazy build, have tried 80w even up to 120w and the tank is hot to touch in a vape ................each to their own.
Question for using unprotected instead of protected when protected works fine is really down to the user. Having extra protection always makes sense if available to the end user. Now i have seen where protected cells have shorted through the strip on the side getting caught. So positives, over and under voltage protection is the usual, too much load trips as well(say 5a or 8a etc variable). Negatives, potential slight parasitic drain, something else in the equation to fail(trip in the field and no way of resetting or having no back up..........). Cell length, some lights are not 69/70mm+ friendly. Cost is maybe another factor, 10 protected cells could be $30 or so ,more over unprotected(just an example).
Now some of my lights(certainly 16650) have PCB's, this is more for length with the extra few mm making better contact. Now these lights are sportac triples and OR mule which dont ask more than 3a. Also being in work, its a little more protection. My sons lights have PCB's, now i take care of the charging etc. If anything fails(like me!) there is a little protection there for a cell draining(say Callum left a light on by mistake........it happens, even us adults can do it time to time.
I am a little OCD with my charging and voltages, every cell gets checked in a charger to mentally note what i have used. If i use a light in work, the cell gets topped up at the end of the day(or 1st thing next morning) ready to go again. Only times i dont top off is when the use has only been a few mins-20m. I dont recall ever a cell getting bellow 3.5v in work, mostly 3.8v and up.
At home i use some more demanding lights, or ones designed around using high drain cells(where even button top unprotected wont fit!). So flat top high drain cells, i make sure my source for these cells is reputable. I only use said cells i know and in good condition, noting the IR each time i top off. Any damage to wraps get replaced there and then.............If high drain cells are required, i make sure their spec is above the required, i dont push any cells above and beyond their specs. Multi cell lights are matched the best i can, again taking note of voltages after use. If one cell is weak(lower V ), then a new batch of 4 would get used, others used solely in single cell lights.
Protected or unprotected, all should be treated the same, regardless of any protection.........with respect and without abuse. Protection may give some a false sense of safety, thinking they can get away with more abuse/neglect.............i am sure it happens. Maybe human nature................just a thought.
Cheers.
