Yes, the first one already finalized. They will all 10 leave here within about 2 weeks or end of November. The only possible slight delay will be the Laser markings on the bodies. ULTRA 85 X/10
Lasering will be done on all 10 the same day or 2 batches of 5. Yours and most others should leave here by the end of November, barring any Laser delay which should be at most another week.
Your unit is here ready for final ballast body assembly. Yours would be one of the first ones out (group of 5) since we have not received any bodies yet for modification from others.
4 bodies will be here and ready this Friday for Lasering, that could be done as early as next week (Thanksgiving week), but somewhat more likely the following week.
You are currently number 2 in the queue and ULTRA 85 5/10.
Expected useful bulb life depends on how much you use 40 watts vs 85 watts.
If you mostly used 40 watts, bulb life is about 1500 hours. Mostly 85 watt usage would be about 10% of that or 150 to 200 hours.
The Lumens output when the 3 different bulbs are new is almost identical.
Lumens at the bulb for all of these 3 bulb possibilities will be the approximately same in the 9,000 to 10,500 range.
Even Identical bulbs will vary by about + 8% so we can use 9800 bulb lumens as the median number.
There is more variation between identical bulbs than the median variation between these 3 different bulbs.
Expected life of the 2 bulbs included should approximate the life of one Fatboy.
