Ian2381
Mine does that, flickering and wont light again when turned off. An indicator you have a depleted battery needed to be replaced.
The purpose of this test is to see how long it takes to completely drained a single "china brand" alkaline in a real world situation. I will not use alkaline for daily usage, but only as a last backup option.
Please check your battery frequently - alakaline batteries are even more prone to leaking (and then damaging lights) when they are drained of all charge.
I'm looking for some good beamshots on H51FW and H51W so I can decide which one to use.
Thanks for all the replies. My H51w behave differently differently depending on the mode.
1) High - It will step to med, no flickering yet unless continue on current level (med) for extended period of time.
2) Mid - It will step down to low, no flickering yet unless continue on current level (low) for extended period of time.
3) Low - It will start flickering after roughly 100 hours of on-off routine use, it will continue to to flicker for roughly 20+ hours of on-off routine use. I am still doing the "L1 mode" test, and right now it has been running 4 hours daily for about a month.
The purpose of this test is to see how long it takes to completely drained a single "china brand" alkaline in a real world situation. I will not use alkaline for daily usage, but only as a last backup option. I also did a test on "H1 mode" with Energizer Primary Lithium", and the result is roughly the same to Selfbuilt review for the SC51.
The other lights in my test are the Fenix LD20/ LD10/ LD01 SS/ E01, Sunwayman M20C/ M10A, Jetbeam III M and Klarus ST10/ Mi X6. The Klarus X6 are doing pretty well with just a single AAA, hitting 80hours on "low" with 2 hours of usage daily. The LD01 SS only manage to reached 55hours before shutdown. This test are by no means as scientific as what other "Gurus" here had did, but more like an insurance for myself, to know exactly how long each light will last with different battery options.
Found a companion for my H51w
