Using a set of verniers i measure 1mm or 0.039" difference between the two sides the cap is off. It can be felt easily when in the hand if you rub your thumb up and down on the knurling on the side of the battery cap, and do it all around basically one side it is flush with the lanyard band and one side the lanyard band sticks out - this is not the side where the lanyard ring is located its about 90degrees from the ring, basically if the side with the logo and switch is the front, the lanyard hole is the back then im talking about the other two quadrents - left and right. I dont know whats off center, maybe its the lanyard 'band' or everything from the underside of it and up.
There are also some deep machining marks covering approx 1/4 of the dia. of the body in the section under the lanyard 'band' seen in the 2nd photo. So perhaps the light wasnt in the tool straight in the first place i dont know.
Other marks in the anodizing can be seen in the battery cap, it feels smooth where the marks are. I havent bothered taking photos of everything i originally mentioned but can do if anyone really wants to see my every complaint.
Example of anodizing marks
Gouging in the area under the lanyard 'banding'
Battery cap is about flush on the right side, but off on the left.
Compare the left to the right side, the shelf between the oring and the edge, its 1mm difference from the left side to the right.
