[ QUOTE ]
idleprocess said:
I was just addressing the tangential issue of "battery" vs "cell" in that statement.
Since this isn't a portable operation, there could be a case for simplicity at the expense of some efficiency.
A current supply is a good way to go, since LEDs regulate their own voltage handily if current is restricted.
[/ QUOTE ]
idleprocess,
Howdy. I'm sorry for misunderstanding your intent, you're absolutely right, the common '9 Volt battery' is indeed an excellent example of the 'battery made up of cells' idea. So few folks agree with me, I'd be shortsighted indeed not to agree!
If you check back to the very start of this good stuff, you'll see that efficiency is indeed very important. The original chap lives off grid and is dependent on solar power (which costs about $10/Watt for average five hours a day, less in winter). Although it is often quite true that lots of available energy changes the efficiency/cost/simplicity balance.
Also, I think all are in agreement that current regulation is better than voltage regulation. For that matter, probably all but a few would agree that regulated circuits in general are superior to either resistored or DD set ups. FWIW, the sorts of regulators we're talking about (as opposed to switching *converters* like in the ARC AAA or MM) in general have 'exactly' the same efficiency as a resistored light would running at the same point. The regulator is, if you will, a 'smart resistor' basically. That is it's a variable conductor (resistor) who's value is automatically varied by a control circuit. The circuit is 'looking' at something (like the actual current or voltage delivered to the load) and trying to adjust things to match it's own idea of the ideal value (which is hopefully the one we've told it.....).
Again, sorry for the misunderstanding, thanks for adding to the discussion.
Doug Owen
