PhotonWrangler
I told you not to put marshmallows in the microwave...
I doubt it. The foam in the pictures is a part of a fire extinguishing system designed to snuff out flames by covering them in flame-retardant foam and cut off the flame's oxygen supply. Likewise, it would do the same for humans.PhotonWrangler said:Holy cow! Can a human breathe in that stuff?
DUQ said:"Clean up in aisle 12, clean up in aisle 12!!"
carrot said:I doubt it. The foam in the pictures is a part of a fire extinguishing system designed to snuff out flames by covering them in flame-retardant foam and cut off the flame's oxygen supply. Likewise, it would do the same for humans.
If you were caught in this with no way out, I'd guess you should wave your arms like a maniac in front of you in hopes of popping the bubbles and freeing up some air. Just a crazy wild guess.
-Bill[font=Arial,Helvetica]Also, if you're surrounded in AFFF foam, just swim your arms around infront of your face and you create an air pocket that you can breathe. Unless it's Baricade Foam, but that's a different story and not something they'd use in a location like this.[/font]
PhotonWrangler said:Thanks for pointing that out, Bill. Hopefully I'll never be in a situation where I need to use that knowledge!
I've gotta wonder whether it's normal for the foam to be released when the power goes out. Is there some obscure safety regulation that states that a power outage could be caused by a fire?
carrot said:Whoa. I didn't even read the article, I just guessed...
I wonder what went wrong and why the foam system didn't auto-shutoff?
