No. The rear clickie is just an on/off switch. Twisting the tailcap will only cause the light to turn off. To adjust brightness you turn the head. All the way tight, (clockwise looking down at the lens) is full on. Twisting the head back a little (counterclockwise) will set it to low. It only takes a slight turn from the tight position to get to low. Any more does nothing.
