Ever wonder....?
Take a few apart, weight them, uses a micrometer, etc.
Seriously, its not a good idea to take them apart unless you know what you are doing and have a method to dispose of the hazardous materials safely (Your garbage can is NOT disposing of them safely).
But the easy way is to talk to some of the folks at the R&D departments of the major battery companies.
My understanding is that the major improvements in the beginning was the density of the metallic film in the batteries. But that soon peaked, hence the 2000mAh batteries.
To get past the 2000mAh barrier, some packed a few extra turns of foil in, and the 2100 and 2300 mAh batteries were born, but with some that also came with a slight increase in diameter.
AS of late......i.e. the 2500mAh and above batteries. Some are fine tuning their metallic film alloys and/or cathode anode structures, but MOST are actually using a thinner seperator material (i.e. Energizer) so they can get a few 'more' turns of foil in there. Hence the high self discharge rates that we are seeing in the 2500 and above batteries.
