I have questions concerning rechargeable batteries for three lights that I have. Rather than start three topics I thought some of you may prefer that I consolidate them into a single thread. Thanks to anyone that may be able to help.
Magcharger:
I need to replace the batteries in my Magcharger. I would like to continue using the factory charger. I have seen that most suggest 1/2 D cells. Can someone tell me what I should look for in these cells that will give me the best performance?
Brinkmann MaxFire Xenon Rechargeable:
I have this light and the charger that came with it. It is a decent light but it seems like the batteries are a weak point. Is there a better rechargeable battery that I could use in it, again using the factory charger if possible. The factory battery stick consist of four cells. 2/3A Ni-Cd x 4 650mAh 4.8V.
Surefire U2:
I have seen post stating that an 18650 rechargeable cell works well in the U2. Mine has no plastic sleeve inside. However, I have also read that some of the newer ones no longer use the plastic inserts but the body must be drilled out to accept an 18650. I bought mine used so I have no idea how old it is. How can I tell if the body will accept these cells? Also, could someone point me in the right direction on which cells to buy? I would also need a charger. I don't want to spend a fortune on a charger but would like something that isn't junk either. If I could buy one charger that could be used for the 18650s and for the Brinkman batteries as well that would be a plus.
Thanks to anyone who may be able to help out here.
-Bake
Magcharger:
Surefire U2:
-Bake
