Ok, I've been doing some research and I have decided my next hotwire will be a Mag61.
If I read right the formula goes as follows:
Mag
Phillips 5761 Bulb
7.2v worth of Batteries
Bi-Pin adapter
Borofloat Lens
Aluminum Reflector
For the bulb adaptor I wanted to use: https://www.candlepowerforums.com/threads/179891 so that I can retain the stock cam focus mechanism of the Mag.
However I did read alot of talk about 6.8v being the correct voltage and lots of folks insta-flashing their bulbs.
My mag 61 will most likely have no resistance mods other than a recessed tail cap and that is just to fit in the batteries, I'll be using 6 Elite 5000mAh Sub C cells rated at up to 30 amps discharge.
I worry that a freshly charged pack, or even one that has rested may be too much voltage. I have the same pack in my ROP and it will read 8.4v off the charger.
According to Lux's bulb testing 8v on this bulb is a no-no.
Soooo....can I use the FM Bi-Pin Slug and keep the focus mechanism? Is there some crazy voltage sag that will keep the bulb from going poof? Or will I have to get one of the fancy soft starting switches I keep seeing threads about.
Thanks for the help!!! :twothumbs
Mag
Phillips 5761 Bulb
Bi-Pin adapter
Borofloat Lens
Aluminum Reflector
