I'm not a gadget guy. I need help!
I want a lightweight (one ounce?) hand-held light that uses a single CR123 lithium battery for backpacing in the mountains in grizzly territory. This rules out regular backpacking lights because it needs to be able to shine a bright beam in a bears eyes, not save batteries. I camp in the summer when the days are long and don't need it to set up camp or fool around at night...just bear defense.
I don't know much about lights but I've noticed most high end lights are NOT ergonomic. I need a light that I can grab in the middle of night with my left hand, position and operate with only my left hand because a 44 magnum revolver will occupy my right hand.
I find that end cap switches are very awkward, the only way I can figure out how to operate and hold them is with my forearm in the air at head level. I want a light that I can operate and have better pointing options than that. I will have to have my thumb on the switch 100% of the time so I can't reposition my hand to aim. I might have to turn it OFF in a hurry.
A rear switch might be acceptable if the rear of the light has a flange that I can securely place the first two fingers of my left hand while operating with my thumb. That means there can't be a pocket clip back there to gouge my fingers.
Ideally the light would have a button near the bezel so I can hold it easily and comfortably. Unfortunately most of those kind dont have a shape that tells my hand where the switch is and I have to roll it and feel around for the switch, poor design, IMO. It takes several seconds to find the switch on my Maglite and turn it on at night, ....phooey. That really stinks when seconds count.
I would like a pocket clip if it's located nearer to the bezel away from operating fingers. If not so designed I'll do without the clip.
The beam should have concentrated light in the middle to blind Mr. Griz and a wide beam not so bright to track a running bear (sometimes they circle prey).
I want a simple on-off-on switch without any "logic" or "circuitry" or procedures to memorize (and try to remember in a life threatening situation), but I do want the momentary on option.
For those who don't backpack let me explain than many products are marketed to backpackers as "lightweight". If it's marketed to backpackers as "lightweight" without the true and actual weight being given it is unsuitable for backpackers, period.
Hopefully I can find something like this for under $100 and without having to build it out of different components.
Five hour run time would be OK. Plastic housing preferred.
I'm open to other battery recommendations as long as they are single and lightweight. I will likely install a new battery every trip.
Is there anything resembling my desires out there?
