gcbryan
I searched and didn't see a review of this headlamp even though it has been out for quite a while.
This is just a mini-review. I checked out a friends headlamp today and thought I would add a few comments.
This is a light weight headlamp using 3 AAA's with a weight of 3.1 oz including batteries. It has one emitter with a max output of 60 lumens. This is a spot configuration. There are a few ringy artifacts in the beam but compared to many headlamps it appears to be a fairly clean and spotty beam.
There is a build-in sliding (up and down) diffuser. The UI is fairly straight forward. One click turns it on, two quick clicks for low, three for strobe. If you hold the button down for a few seconds the light flashes white and then goes to red mode. Both white and red modes have strobes.
There is some glare since a strip at the bottom of the headlamp is translucent. There is glare from the tab that raises and lowers the diffuser as well.
Low is 30 lumens (I think). In any event it would be much more useful if there was an even lower low.
My immediate impression was of a light weight headlamp with a decent spot beam and a useful built-in diffuser.
I should add that the battery compartment was fairly straight forward to open and close. You just have to pry open a latch. The UI button on top of the unit was easy to locate and use as well.
My only criticisms really are the glare issue and the lack of a real low. Given the competitions pricing I also think the XP 2 is over priced at the moment. The BD Spot is $40 and wins on paper at least at the moment over the XP 2.
